#1 |
Junior Member
Mini
Member #: 14402
My Sled: 700 Venture
I just purchased a 2001 700 Venture. The sled sat for a few years, it only has 300 miles on it. When I got it I took the carbs off and cleaned them, they looked clean and not gummed up. I also replaced the fuel filter in the tank. The first time out I ran into trouble with it cutting out. It was low on fuel and when I filled it up it seemed to run fine. The next day I ran about 80 miles without trouble and then it started acting up again. It feels like it is running out of fuel. I made it back at 1/8 throttle. If I went 1/4 and beyond it started cutting out. At this time the tanks was full. When I got back I pulled the fuel filter out again and it seemed like it was tangled in the sending unit of the sled. The gas gauge also seemed to never come off full. I was wondering if there is anything I else I could check. I looked for a problem with the pulse line and feed line to the pump. I also ordered a used pump off ebay just to swap out. I will check the vent line to the tank.
Any other ideas? Thanks |
#2 |
![]() Join Date: Jul 2008
Member #: 10208
My Sled: 00SRX,03VIP,03VEN
TORS? Go over carbs again,, may have missed something..... Did you pull jets and clean with wire and blow air through passages?
#3 |
Junior Member
Mini
Member #: 14402
Found the problem, split gas line in the tank right where it connect to the fitting that goes through the tank.
| Thread Tools | |
| Display Modes | |
