TY Forums
Go Back   TY Forums > Yamaha Sleds > Mountain Sled Talk
User Name
Password
TY Home TY 4 Stroke Forum ATV Forums TY Tech TY Mail Register Mark Forums Read
Quick Links TY Chat TY Store VIP FAQ Posting Rules Members List Calendar GuestMap Sled Garage
Reply
Thread Tools Display Modes
Old 11-06-2011, 10:05 PM   #131
A couple of bucks
Senior Member
Open Mod
A couple of bucks's Avatar
Member #: 11669
My Sled: 97 SX 700
A couple of bucks Very good to Buy/Sell with...
Default
Quote:
Originally Posted by A couple of bucks
1st time poster over here on the mountain side.
There are 4 warm air ports that are incorporated into my hood. This pulls warm air from the engine compartment along with the the factory cold air intake. 100% completely stock setup.
The question I have is....if I block off the warm air, and the carbs get all cold air, does anyone see any problems. Besides leaning it out a bit. Still have stock jetting in it anyway, so it's a bit rich anyhow.
Dan
Thinking about this post of mine. If the engine is going to draw pretty much colder air by blocking 1,2,3 or 4 of these ports off.........the engine should be running richer because the air charge is less dense because of the cooler/colder air. I am thinking right......aren't I????????
__________________
Dannyboy
A couple of bucks is offline   Reply With Quote
Old 11-07-2011, 08:08 AM   #132
Mysledblows
Member #: 405
Mysledblows A++ Buyer/Seller
Default
colder air is more dense. so in theory you are slightly leaner by eliminating the warm air that is introduced into the airbox via these ports.
Mysledblows is online now   Reply With Quote
Old 11-07-2011, 09:01 AM   #133
A couple of bucks
Senior Member
Open Mod
Member #: 11669
My Sled: 97 SX 700
Default
That's right. Usually , the colder it is outside, the better the sleds run because it's leaner.
Conversely, at a grass drag, sleds run rich if jets aren't changed.
__________________
Dannyboy
Old 04-08-2012, 02:48 AM   #134
tdorns85
Junior Member
Mini
tdorns85's Avatar
Member #: 18876
My Sled: SRX 700
tdorns85 A++ Buyer/Seller
Default
i bought a 1999 srx last year that draws all of its air from under the hood. I would get bog when im riding in deep snow and when i am carving exhaust pipe outta the snow. So i find it hard to belive that a exhaust deflector will slove the problem. I guess the frusterating thing is... if so many people have had issues with this, myself included why has yamaha not addressd it themselves.
__________________
TDorns85
tdorns85 is offline   Reply With Quote
Old 04-11-2012, 10:44 PM   #135
extremelyfastmax4
Senior Member
Improved
Member #: 10886
My Sled: vmax4800,2010fxnytro
extremelyfastmax4 A++ Buyer/Seller
Send a message via MSN to extremelyfastmax4
Default
my mountain max700 tripple rolled chain case 153 track really likes the deep snow but the motor boggs out so imtaped up the vents on the front of the belly pan and up front no more problems i run with the air box attached and holtzman temp compensator so jetting is allways right so im going 2 say something 2 do with under hood air pressure and possible wet wiring on ignition. it would cut out on 1 cylinder
extremelyfastmax4 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
This site is not an official site of Yamaha Motor Corp, USA or any other Yamaha entity.
Opinions/comments expressed on this site are not that of Yamaha or any other Yamaha subsidiary or affiliated company.
Powered by: vBulletin Version 3.0.3
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
