Results 1 to 5 of 5
Thread: 2005 RX Warrior 136" skid in 1995 VMAX 600
  1. #1
    Member Mini OneSki's Avatar
    Join Date
    Dec 2005
    My Sled
    Looking
    NE OH
    Posts
    37
    Default 2005 RX Warrior 136" skid in 1995 VMAX 600
    Hello guys looking for some help here...I bought a 136 '05 warrior skid and want to put it in my 600 VMAX, can I use the measurements from this install done buy CaptJager?
    http://www.vmax4.com/vbulletin/showt...4-Measurements
    Or do I need other measurements? Also any other advice on the install would be great. Thanks much for your time! Also I put a pic up of my sled has been a work in progress.
    Attached Images Attached Images
    Current sled - 1984 Phazer
    Currently building - 300 Enticer
    '76 TX 440 F/A,
    '78 TX 340 F/A,
    '93 XLT SP,
    '97 SX700
    '99 Z 440 Snopro
    '85 SS440
    '82 SRV
    '95 VMAX 600
    Summer toy: 28 ft Chris Craft
    THINK SNOW !!!!!!
  2. #2
    Senior Member Stock
    Join Date
    Oct 2008
    My Sled
    Vmax4s 750-800-880
    BC Canada
    Posts
    105
    Default
    ........................lts hard to see from you pics what lenght skid is in the sled, 121"?
    lf so you will need to extend the tunnel and modifiy/move the rear heat exchanger, get another track etc.
    The lug height of the track/type of track will have a bearing on where you put your skid as will different drivers.
    The link on you post dosent work, dont panic if you cannot get a template, there are some measurements /dimentions you will need to get of the/a doner.
    1, Distance and angle from drive shaft hole to front mounting point.
    2, Distance and angle from front mounting point to rear mounting point.
    You may find if you mix tracks/drivers the distance between the drive shaft and front (and therefore rear aswell) mounting point may change slighty , this hasnt been a problem for me in the past, however i belive its important to keep the angles close to stock as possible (and also the distance between front and rear mounting points), this will affect how the skid works.
  3. #3
    Join Date
    Dec 2005
    My Sled
    Looking
    NE OH
    Posts
    37
    Default
    1993vmax4,
    Thanks for the response...Yes the sled is currently a 121 and I figured on stretching the tunnel and new track etc...But would I have to change my drivers on the drive axle? Or could I just use whats there? BTW I did email the guy I got the skid from to see if he could get me the measurements from the doner. I also posted some ?'s on the 4stroke section of the fourm to see if anyone could help me out with that. I also don't think I'll run more than a 1in track due to nature of how and where I ride....Any advice on the tunnel streching or heat exchanger relocate would be helpfull...As this is my first attempt at making a slightly modified sled...Thanks again!!!
    '76 TX 440 F/A,
    '78 TX 340 F/A,
    '93 XLT SP,
    '97 SX700
    '99 Z 440 Snopro
    '85 SS440
    '82 SRV
    '95 VMAX 600
    THINK SNOW !!!!!!
  4. #4
    Senior Member Stock cliffordtom's Avatar
    Join Date
    Mar 2009
    My Sled
    srx 151
    negaunee michigan
    Posts
    107
    Default
    my buddy put a 2 inch paddle in his v max and had to change drivers but you should b ok
  5. #5
    Senior Member Stock
    Join Date
    Oct 2008
    My Sled
    Vmax4s 750-800-880
    BC Canada
    Posts
    105
    Default
    Quote Originally Posted by OneSki
    1993vmax4,
    You dont have to change the drivers, some people who put longer tracks on also want to run looser tracks (frees up Hp) and run extravert type drivers.
    lf you are in touch with the skids PO try and get the driver diameter, also measure your driver diameter, that way you can figure out if the skid has to be mounted further back or closer to the drive shaft.
    A popular way to get around the heat exchanger problem is to cut the bend out of it and weld it flat.
    You can buy tunnel extentions online for around $150-$180, get a factory extention from any 136" vmaxs of that era, maybe other yammaha models?
    The stock extention from a breakers/evilbay would give you a very 'factory' finish with a bit of paint.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
